Originally Posted by SLK32Germany
Thanks. I think ECU-Adaption will be needed and from what I heard, you have to be careful to adjust the water/alcohol injection very accurate, control water/alcohol level in your tank etc... Some people had engine-problems with such a setup... Maybe it is more for the "hardcore" dragracer than the daily driver. If it is installed correctly, it sure gives more power...
nah it is only an issue if you go crazy and start replacing too much fuel with alcohol and go nuts with the timing advance.
