Thread: Upgraded IC?
Old Oct 30, 2008 | 07:48 PM
  #58 (permalink)
mrphotoman's Avatar
mrphotoman
Default Re: Upgraded IC?
Originally Posted by Bulldogger
Alcohol injection is usually for higher hp applications where cylinder temps need to be cooled down. You can run it but it does increase cylinder pressure, which is harder on head gaskets. It is usually used more with diesels because they can climb too 2000* degrees on egt's on a 1/4 mile drag on a hot tune, or sled pulling. I don't think I personally would go that route because you need to mount a reservoir bottle or hook up to the winshield washer tank. Usually it is a trouble free set-up, once you dial it in. But you always have to remember to fill and check the tank.
that is not true at all, you can use meth injection on any car. you can use it on a n/a car or a fi car. it cools temps, raises octane and all the other benefits i posted above. as for increasing cyl pressure, it does a minute amount because it is only spraying a very fine mist. you would have to be spraying an insaine amount to raise cyl pressure.
whoopity doo yeah you can take 2 seconds to mount a tank or you can tap into the stock washer tank which has a low level light on your dash. a tank lasts around 400 miles.
