Originally Posted by srt-6novice
what was the name of the part you purchased for the front camber from the dealer. also what is the size of your wheels and tires.
The front bolts was called an eccentric camber bolt kit for $14 a side. The front wheels are 18"X8.5 with 245/35/18's tire's and the rear wheels are 19"X9.5 with 285/35/19's, both front & rear wheels were a 35mm offset. I also have 10mm hub centric spacers on front and 20mm's on the rear.
