Thread: Upgraded IC?
Old Oct 31, 2008 | 05:13 AM
  #61 (permalink)
Bulldogger's Avatar
Bulldogger
Default Re: Upgraded IC?
Originally Posted by mrphotoman
that is not true at all, you can use meth injection on any car. you can use it on a n/a car or a fi car. it cools temps, raises octane and all the other benefits i posted above. as for increasing cyl pressure, it does a minute amount because it is only spraying a very fine mist. you would have to be spraying an insaine amount to raise cyl pressure.
whoopity doo yeah you can take 2 seconds to mount a tank or you can tap into the stock washer tank which has a low level light on your dash. a tank lasts around 400 miles.
No sh*t sherlock you can use nitrous on any car too, point is it is usually used in more heavy duty race or pulling applications in general, I don't think mom and pop use it to go to the grocery store. Also being you set it to spray based on boost pressure you can use quite a bit in a short period of time, but then hey you know it all anyway
