Thread: Upgraded IC?
Old Oct 31, 2008 | 09:02 AM
  #75 (permalink)
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: Upgraded IC?
All right you guy's - let's give it a break.
Let see some some mods, with pictures part numbers and results.....
If you like to spray - spray - If not - not...
You can always do both - add a bigger HE and separate the coolant systems - this is cheap enough and if your IAT are still raging - use the spray.
OR - you could always make an inexpensive sensor clamp for the IAT - - and signal the ECU that your intake temps are always 78 Deg F and never pull timing...
