Old Oct 31, 2008 | 12:05 PM
MikeR's Avatar
MikeR
Default 240's modified Intake Manifolds
Here are my results so far with the newly installed modified intake manifolds from 240M3SRT6. I posted pics of the manifolds installed in this thread...
https://www.crossfireforum.org/forum...ad.php?t=28936 and another pic below.
I went to PIR on Wednesday night and got four runs in on the new mani's, new LET tune and DR's. Time slips are here:
https://www.crossfireforum.org/forum...ad.php?t=29223
My previous best was 12.5 @ 112.6mph and with the mods I did a 12.2 @ 111.4mph. My 60' times were pretty good at 1.8 but the track felt a little greasy. Especially the second two runs. When I get back on Woodburn(next season) I think I will get much better numbers. They prep the track very good.
I was checking the install today and found one hose clamp loose at the Y on the drivers side and it would not cinch down. Got four new ones to fix that. I think I need to put some miles on the ECU with the new tune and mani's. I will setup to get on the same Mustang dyno I have been using and get the new numbers asap. I need to see what my AFR is now and make sure it is good.
All in all I am very happy with the new manifolds. The car feels much faster and stronger. Unfortunate that we got this done at the end of the season up here. Rain today, rain tomorrow, etc. etc. That also means I cant play on the freeway either.
MikeR
I just got back from the dyno. Here is the graph. This is on the same Mustang dyno I have been using.
Previous dyno: 313whp max 310wtq max
New Manis: 325whp max 343wtq max
I dont know what the delta is between DynoJet and Mustang but have heard 15% to 20%. At 15% that would put my max whp at 373whp and 394wtq. I guess I will have to find a DynoJet and see for sure.
I have about 250 miles on the new setup and the car feels GREAT! Everything here is wet these days so I can go out and give it a good test. What driving I have done says the car is quicker and stronger.
I will send the data file to Jerry and see if he thinks we can tune it up more. You can see my AFR was 12.5 to 12.9 on the dyno and the boost was at 18psi. I hit 20psi at the track before the modified mani's. I am VERY happy with the mod and it took my 1/4 mile time from 12.5 to 12.2 on a track that wasn't prepped. Did I mention that I was happy?
MikeR
