Originally Posted by aftcg
Thanks for the info guys...Where does one pick up this "special" tool? P/N?
Well unless you want to spend a bit of $...
The "tool" is about $60-$80 (it is a dip stick with different measurements on it)
Miller tool
8863B (about the cheapest I have found)
Next you need a scannner to get the exact temperature of the fluid so you can determine where the fluid level should be located on the dipstick.
(most cheap scanners do not give trans fluid temp)
