Old Nov 5, 2008 | 07:25 PM
04Fire's Avatar
04Fire
Default Re: Tire Pressure Monitior System
Originally Posted by frantastic_car
The TPM icon is lit on my dash and I have had all four tires checked and all have the correct amount of pressure. The tires are not worn and the temperature has been between 52-76 degrees. Should I worry?? Any advice??
You'll be fine as long as the cold tire pressure is correct... I just had my dealer reset my TPM sensors because I put different wheels on and now the light is out. You'll Need the DBR III scan tool to do it and a some other tool... I watched them do it it's pretty cool and took about 5mins.
