Originally Posted by brian_omeara07
What I am going to be doing here in just a bit is pretty easy to do and looks clean as you know what in my opinion. Under your "trunk" we have that little area with the fix a flat and such...well all of those materials can be moved to the LEFT side easily if you stuff it in there, that leaves the other side completely open. Take out the foam, Put in a sub, keep the cover velcro'd down a little tighter. Should mean that the only thing showing in my Xfire will be the Amp, which I may just hide that behind the driver's seat (if i can get away without hitting the stock subs)
Going to be running 1 Eclipse 10" 300 RMS DVC sub (150/coil) with a HiFonics Brutus I have sitting around. Some day I'll take some pictures of the sound system from the Sunfire...THAT's a loud car.
Question as a side note, does anyone know what size the stock subs are? because if they're a semi-normal size...stealth install FTW...
They are 6.5 inch drivers. I have hidden my amps. I haven't taken a picture of it, but I will post it on here soon.
