Thread: Upcoming Mods?
Old Nov 6, 2008 | 06:29 AM
mrphotoman's Avatar
mrphotoman
Default Re: Upcoming Mods?
Originally Posted by BLKFIN
4. SC pulley along with a LET re-tune. I also might need larger injectors at this point......In my opinion, the 178 + the SC pulley will compliment these NW Intake mani's quite nicely. I saw about 2.5 to 3 psi decrease from adding the NW mani's so by adding the SC pulley, we would not be maxing out the map sensor as Eleventeen did.
Has everyone with these manifolds seen a decrease in boost levels?
you flow more air so you make the same or more power on less boost. it makes it more efficient so less boost does not mean less power. you have more airflow with less heat because of the lower restriction and that is a good thing. more boost with more heat from more restrictions=less power.
