Old Sep 2, 2004 | 04:35 PM
  #131 (permalink)
Sam's Avatar
Sam
Default
Originally Posted by BluBlur
TY so much for that info. Looks like I may have to turn my Cusco's in since this very reputable mag did this test. Anyways, from what i think you said, they just did very minor adjustments. I see you said that they didn't change out the control arms which means that it was the standard 0 camber of the Z's stock suspension correct? If so, that is quite incredible with no camber. Wonder how much better it would be with 1-2 degrees extra.
When I say stock suspension, I mean stock, no nothing was added onto the settings/adjustments, the dampers, the springs, nothing. Only the swaybars and rims and tires. As a matter of fact SCC said its pointless to change a thing on the stock Z suspension, even with the Nismo stuff, SCC said it was that good from the factory.
