re: HID Install Lows and Fogs with Pictures
I installed using these directions and I must say they are very helpful!
I did a couple things different though:
I used an 11/64 bit to drill the holes in the grommet that is on the hid bulb wires.
The hole is big enough that you can push the male plugs through (with a lilttle force) without having to cut them off and re-splice. The hole is still small enough to provide a waterproof seal.
I had no need to move the overflow tank. Perhaps my hands were small enough. It was never an issue for me.
I mounted my Ballasts in the same place but again I still had plenty of room under the tank to install it without moving it. You may want to give it a shot to save you some time.
Here is a quick pic with my phone. 6k bulbs.
