Old Nov 9, 2008 | 12:03 PM
waldig's Avatar
waldig
Default Re: Solved pebbles-in-a-can sound
I would suggest that you get a bar to realign the pipes, the heat is terrific and the house will stink and probably burn.
It will take some effort, you could assist yourself by loosenin g the 12 and 13 MM bolts where the pipes to the resonator connect to the rear cats, then shift the pipes and retighten the bolts. Be safe under there, Woody
