Re: V8 Crossfire Conversion Diary
Use heat shrink, goes on first, and solder the leads, no problem as no sensors are low ohms, many are in the 10,000 range and a splice thats soldered should add less than a single ohm. Not acid core please. Avoid crimps like, hello whats that a loose wire?????? I add two layers of heat shrink and sleep well.
Wired up Woody
