Old Nov 10, 2008 | 10:44 AM
mrphotoman's Avatar
mrphotoman
Default Re: LET 185mm water pulley failure (WATCH OUT)
Originally Posted by Montana Crossfire
Far from Bullet Proof.
Now the Factory design is bullet proof!
Now I am hearing "boy I am glad I have a super charger pulley" Why? Now that the only problem with the LET system has been fixed the only differance
is you barely have over half the boost!of the 185mm
From what I have heard from you in the past was, that your still looking for more power.
Yes the truth is the only (RECALL) was on the 181mm pulley but Jerry will have no problem replacing the 185 water pump for you and then everything will be once again Honky Dory
less boost but we run faster times
