Old Nov 10, 2008 | 12:21 PM
rodimus's Avatar
rodimus
Default Re: LET 185mm water pulley failure (WATCH OUT)
Originally Posted by BlUEMDsrt6
I was driving back from my girlfriends house when this happened. I was on a long straight road leading up to my apartment whenIi tried making a hard right turn at decently high rate of speed. When I was originally turning with one hand, but the steering wheel was super tight and hard to turn so I eased onto the brakes and turned hard with both arms. For a second there I was afraid it wouldn't turn and I would have to take extreme emergency measures. I didn't hear the initial break of the pulley or when exactly it gave way because I had my radio up loud. I only noticed once I tried to make the turn. I originaly thought just my power steering went out, but once I parked it and popped the hood I seen my belt totaly destroyed. After seeing the belt my eyes went straight to the water pump pulley and sure enough it was desintegrated. I do not know the extent of the damage other than the belt and pulley as I had no time to further investigate. I am not sharing this story to bash LET, but to worn others because this could have had disasterous results. Anyone who has an LET pulley of any size needs to ask for a new and improved water pump pulley ASAP and be careful until then.
It's Patriot fan Karma.....
Half your team is injured and now your car is on the DL. At least you still have your helmet....
