Old Nov 10, 2008 | 12:22 PM
BlUEMDsrt6's Avatar
BlUEMDsrt6
Default Re: LET 185mm water pulley failure (WATCH OUT)
Originally Posted by mrphotoman
We as in several people on the site showing valid timeslips with code3 pulleys are running faster times than most (i am sure there is an exception) of the 185mm pulley guys because the 185mm pulley generates more heat. If someone adds alcohol injection or even a small shot of nitrous to cool the intake temps then I am sure the 185mm pulley guys will be faster. However, as it stands the code3 and their little tiny psi increase actually are faster. The timeslips show that and the 185mm pulley timeslips I have seen are not much better than a stock srt6 runs.
Regardless, that is what is fun about modding your car. Trying something different and seeing what works best.
As for the water pulley failure, lets hope no metal shards hit anything important and you get your car up and running again soon.
All true, and my fingers are crossed that the only casualties are the belt and pulley.
