Re: Battery problems-again!
Took it to a battery shop, they said drain was nomal 500 milliamps, that better? I also took a 12volt,single element bulb& hooked it in series to the disconnected negative cable & on the initial touch, the lite was brite & went completely out in about a second, as it was indicated in the directions, was a normal drain. Also does the new interstat battery have the same outward physical appearence as the original Crossfire battery,white case etc ?
