Old Nov 14, 2008 | 09:11 AM
amx1397
Default Re: Probelm with ashtray... stuck. need help
take a plastic knife and raise the panel below the ash tray,, in front of the shifter raise it up and reseat it , the ash tray will now open ans close also check the shifter ring and see if it was installed backwards if it is correct there is no clearance under ir if one end sticks up anywhere it is backwards
the problem is the panal below the ash tray is not installed correctly or has come loose (up) jim
