Old Nov 15, 2008 | 03:45 PM
ppro's Avatar
ppro
Default Re: just got home with my new system
Originally Posted by 07bluezx14
I have never replaced an alternator, I would assume you can get them checked, at autozone or similiar place. If it was in my cobra, That wouldn't be a big deal, it is stareing you in the face. Are they hard to get to on our crossfires? So you think it is the alternator, not the battery? which should I look into first. thanks, chris
At idle your alternator isn't putting out it's full charge. The 120 amps is at or above 2200 RPM. At idle your pretty much just on the battery. (That's the way the car is designed)
There's probably nothing wrong with the alternator if your car battery is staying charged and the car starts without problems.
You could turn down the stereo when you're at idle and probably not have any problems...
The "Big Three" article is interesting - putting 1 gauge wire will certainly assure the most power reaches the components but if you haven't replaced an alternator before, don't do this - if you don't get it right you'll burn your car down.
