Old Nov 16, 2008 | 12:27 PM
tighed1's Avatar
tighed1
Default Re: I sure am glad I found this site!
If the car won't start try this.
Open the hood and locate the black box located to the right of the battery.
The relay control module is located inside. Give the box a couple of good raps with the handle of a screwdriver or similar object. If the car starts, you might have just found the problem.
Remember if it doesn't start that doesn't eliminate the RCM as the problem.
Look into the crank sensor also. Both give similar symptoms.
Let us know what you find out.
Good luck!
