Old Nov 16, 2008 | 01:45 PM
James1549
Default Re: Car won't start!
Maybe you need a regular battery charger. Some chargers will not work when your battery is completely dead. Can you push the car out to get a jump start from another car?
It is possible that your battery has internally shorted and not matter how long you charge it, it will not take a charge. With an internally shorted battery, sometimes a jump start will not work either because the bad battery is using up all the current.
If you get the car started by jumping it from another car, do not let your alternator charge the battery back up to full charge. Your alternator is designed to "maintain" battery voltage, not recharge it from the dead. It will work, but it could also shorten the life of your alternator since you are working it to full capacity for a long period of time.
There are many things that can happen to cause a 'no start', this is just the begining.
James
