Old Nov 16, 2008 | 04:43 PM
rcompart's Avatar
rcompart
Default Re: Trunk - Plastic removal
You should just be able to pull it straight forward toward the front of the car. You may have to pull the part that the latch goes through out. It is about 4 inches wide right in the center of the panel. It will lift out of there with some work. There are 4 compression clips behind it that will come out with the panel.
