Originally Posted by MD SRT6
Sorry to disagree but I run a clean 12.5 all the way to redline, with enough fuel to supply my wet shot of nitrous all the way to a 150 shot. Stock fuel pump and stock injectors. With a run of 10.71 @ 131mph =??HP. + With no Juice 11.59 @ 122 = ??hp. I have over five ecu chips that I can switch out depending on what type of gas, nitrous or not I'm running, And have never run lean, I think you guys are missing some vital tuning parameters that can be unlocked!? How many hp does it take to run above numbers? check it out on a hp calculater! I haven't dyno'd in a while but have put up well over 400 to the wheels with all stock fuel components. And I believe our stock injectors are 42#? Psi 55? Not sure about the volume though, but looking at my numbers, I'd say good enough! Please don't start banging me out, this is just my factual experience.
Im on an LET tune. IIRC you are running an inmotion tune, right?
Are you running your car in 50 degree or colder weather?
What AF gauge are you running and exactly where is the sensor mounted?
