Re: Easiest place to tap into a switched hot wire under hood of srt6?
from the ecu compartment. If you remove both ecu and fuse block you will see the passage clear all the way through the firewall. I used this for my zietronix, and it's completely stealth. You can't even tell where the wideband wires are coming back in. It looks completely stock.
