Old Nov 17, 2008 | 06:58 AM
mrphotoman's Avatar
mrphotoman
Default Re: Easiest place to tap into a switched hot wire under hood of srt6?
Originally Posted by cruzinquick
from the ecu compartment. If you remove both ecu and fuse block you will see the passage clear all the way through the firewall. I used this for my zietronix, and it's completely stealth. You can't even tell where the wideband wires are coming back in. It looks completely stock.
that is nice to know, thanks.
where did you tap into a switched power supply at?
