Old Nov 17, 2008 | 02:29 PM
rcompart's Avatar
rcompart
Default Re: Amp and Cap install question.
You want to connect the amplifier ground to the chassis adn the positive wire from that should connect to the (+) side of the cap. You also connect teh (+) ofthe cap to the (+) terminial of the battery and the (-) side to the chassis. If it's easier, You can just connect the ground from the amplifier the the (-) side of the cap. Here is a diagram that should help explain.
