Old Nov 17, 2008 | 08:02 PM
  #51 (permalink)
TVT_DESIGN
Guest
Posts: n/a
Default Re: My 181 install experience. Boost levels + concerns & thoughts
Originally Posted by MD SRT6
Inmotion tune+ piggy, FJO wideband right after warm up cat straight into datalogger. Been running the car for a year now, through lots of temp ranges, many tunes , many mods, and have allways been able to keep it in the safe range. My only point is before we all just assume the injectors are the problem, more research is necessary. Our injectors are HUGE as far as modding goes, I don't know of many cars that have bigger injectors, even on big hp V-8's. If anyone can name some cars with bigger than 42 lb. injectors please let me know.
Any high HP FI motor 4 cylinder will have larger injectors, and a lot of 6 cylinder ones as well.
I'm pretty sure the stock injectors are 34.8ish lbs but run at 44ish due to the 4 bar fuel pressure.
