Old Nov 18, 2008 | 01:26 PM
James1549
Default Re: Replacing Cupholder with Storage Bin / HOW TO
I just replaced my cup holder with the $38 bin. I followed the directions above that helped but there are few things that can be confusing and need corrected.
The most confusuing part is that most places in the instructions that are referred to as a shift lever is the parking brake lever. I never had to mess with my auto-shift lever at all. Standard shift different?
The rubber handle on the park brake lever slid off with some effort but nothing extra was needed to remove or reinstall.
If you lay a towel or blanket on the passenger seat area, there is no need to disconnect the mirror switch wire harness. The console will lay on the blanket with no trouble.
The two nuts in the console storage area use a 10mm socket.
I really did appreciate the help the instructions gave, just needed some clarifications.
Thanks, James
