Old Nov 19, 2008 | 06:00 AM
sonoronos's Avatar
sonoronos
Default Re: Stiff Shifting - 2nd Gear
Originally Posted by mocman68
I have a new '06 Coupe (1400 miles) The throw from 1st to 2nd is sometimes difficult to make.
This is why buying early Crossfires with low mileage is risky. In some cases, you're getting a bargain, but some early cars have what are essentially "unfixable" problems from the perspective of cost and time.
The 6MT transmission was known to have hard shifting issues in 1st and/or 2nd gear. To my mind there's nobody who has "solved" this issue short of using the "shift harder" method. There is a TSB out on lubrication of the input shaft and splines, but to me the issue sounds to me like the synchronizers themselves are either faulty or out-of-spec. So, who're you gonna call? I have no idea. Someone would have to open up the transmission and examine the 1-2 synchro assembly. My guess is that this is neither cheap nor easy.
That's why before anyone attempts to purchase a used Crossfire with a manual transmission, they should always drive the car first and check the transmission.
