Old Nov 19, 2008 | 05:10 PM
Squirrel Crusher's Avatar
Squirrel Crusher
Default Re: anybody ever have a temp sensor go bad?
My ambient temperature sensor got bumped from the side. Replaced the lower grill and temperature sensor. The sensor's plastic mounting bracket now want securely hold the sensor after the side bump causing the hole to slightly enlarge. You might know the cheap plastic bolt on bracket isn't a replacement dealer part. If I can't find a wrecked crossfire somewhere to remove the part,I'll have to melt the bracket with a heat gun then squeeze the hole back smaller. Squirrel
