Hi guys I am planning on installing a hid ballast using a harness, relay and fuse running direct to the battery. I have a adapter i will plug into the h7 plug on one side of the car to get a signal to trigger the relay to send power to the HID ballast. I know I need load equalizer since one side will have nothing plugged into it at all and the other side will have just the trigger to send to the relay. I am guessing i need 2 load equalizer can you tell me what ohm, some threads say 3 ohm and some say 6 ohm but they are referring to people using those for led lights. since i am using hid and don't want the warning light to come on what do you recommend. here is the website where i will get them.
http://superlumination.com/equalizers.htm
