Old Nov 22, 2008 | 03:18 PM
lacerdaschoon's Avatar
lacerdaschoon
Default Re: HELP Mods related
[quote=MikeR]Using the autostick is wonderfully simple. Put it in first. stomp on the gas and HOLD ON! The car will run every gear right up to red line and then shift. If you are crusing you just down shift a gear or two and get on it. The transmission will not let you hurt it. If you try to shift to something that will over rev it will not do it. It will pick the safe gear and take off.
Thanks MikeR i was unsure whether it would shift for me, the engine gets real loud and i get the feeling its going to explode! I will now have to test that out. Its also great to know i can expect alot more from the car once i get more miles on the clock, really seems like a big difference from your explanation.
I notice this car has a massive pull if you give it some then lay off, the revs stay high then you put your foot down. All i do is tap the accelerator and she jerks forward so aggresively, scarily fast! It is addictive! I see you have 2 SRT-6 your a real enthusiast.
What is an SSB? Also i was curious why theres no 5th gear with you use the auto stick, i can go from 1-4 then after that it goes back into drive.
