CERAMIC BEARING
1. RMADERMAN
2. tighed1
3. distantpulse
4. moparrbust
5. AMA FIRE
6. SRT6-Man
7.
8.
9.
STAINLESS BEARING
1. Bulldogger
2. Waldig - Woody
3. Bluemdsrt6
4. MDSRT6
5. Cruzinquick
6. PA/ XFIRE
7. BrianBrave
8.
9.
After all my yapping, maybe I had better sum up my thoughts on the Stainless Steel bearing:
1, It can only take 80-85% of an equivalent steel bearing load
2, The RS seal is good only at 35% less speed than a Z seal (20,000 less 35% = 13,000 rpm) 2RS means it has two seals, one on each side.
3, The cage the ***** run in also has to be correct for the highest speeds
These limitations make it
worse than the stock seal fitted with Z or V seals.
