Old Nov 25, 2008 | 09:15 AM
04xfirecoupe's Avatar
04xfirecoupe
Default Re: problems starting
I have had to replace crank sensor and I repaired my RCM. When the crank sensor went out, the car would turn over about 10 times then stop and . With the RCM the car wouldn't even turn over though everything worked still besides the engine starting.
The RCM, in the black box with the two slide-bar locks, is in the tabbed out portion of the box closest to the engine (furthest part away from you if you're standing on the passenger side). I've attached a picture so you can kinda see the area I'm talking about. It's under a mess of wires and fuses. The module is in a small black cover that is removable once you unhook the cables and fuses (one large fuse and 5 or so small ones).
