The engine, transmission and diff. from CLK55AMG build 2002 fit in the crossfire, regular or srt6! Same scale and fixed points! Only cut the rotor shaft from the CLK! Fixed the cooling fan and exhaust pipes from the CLK and the mechanical part itīs done
On of the importent job is to conect the V8 ECU and the transmission ECU to the based Crossfire ECU they are already inside! Some special work required from an electrican. You need the wiring diagramms from both cars. But itīs works!
regards Max.
