Old Nov 29, 2008 | 06:11 PM
  #45 (permalink)
TVT_DESIGN
Guest
Posts: n/a
Default Re: Mercedes Air Box W/CAI
Originally Posted by jbomar
TVT_Design
@ $395 with K&N's I'm in! Any chance the XFire K&N air filters I just bought fit this MB Box??!! The polished intake tubes look great. One question.....do the new intake tubes connect to the "oval" ports that are mounted on either side of the radiator? These seem to be real restricted points to me.
With this new breathing system I have two additional Q's:
1.) Do you recommend anything on the exhaust side to further help?
2.) Does this increase flow enough to benefit the larger injectors and ECU re-program you were offering in an earlier group buy?
The Crossfire KN will not fit, much too small. The pipes will fit the oval holes, but it is much more beneficial to remove those pieces and have a full 3" opening.
This will benefit from the injectors and ECU tune as much as the CAI.
Magnaflow sells a very affordable system. Not necessary, but will add a nice sound.
