Old Dec 1, 2008 | 04:52 AM
taylormanss's Avatar
taylormanss
Default Re: I sure am glad I found this site!
Originally Posted by Stogey
Read the posted threads carefully !!!
A defective crankshaft position sensor will allow the engine to turn over but not start.
If the relay control module is defective the engine will not turn over period, but all of the accessories will be operable.
Turn the key to the ON position, don't try to start it, do you hear the fuel pump coming on to prime the system ? If not, it's probably the RCM !
Just my Dos Centavos
I'm pretty sure i can hear the pump coming on when i turn the key, but the car won't start. how hard is it to change out the crank sensor? from what you guys are telling me is that it could be the fuel pump relay, the relay control module, or the crank sensor right?
