Originally Posted by huudoo
found this
2. What's Covered Under
DaimlerChrysler's Warranties
2.1 Basic Limited Warranty
A. Who Is Covered?
You are covered by the Basic Limited Warranty if
you are a purchaser for use of the vehicle.
B. What’s Covered
The Basic Limited Warranty covers the cost of all
parts and labor needed to repair any defective item
on your vehicle supplied by DaimlerChrysler
Corporation that is defective in material, workmanship
or factory preparation. There is no list of
covered parts since the only exception is tires.
WHAT'S COVERED UNDER
DAIMLERCHRYSLER'S WARRANTIES
You pay nothing for these repairs. These warranty
repairs or adjustments — including all parts and labor
connected with them — will be made by your dealer at
no charge, using new or remanufactured parts.
I. Parts Covered
The Powertrain Warranty covers these parts and
components of your vehicle's powertrain:
Gasoline Engine: cylinder block and all internal
parts; cylinder head assemblies; timing case, timing
chain, timing belt, gears and sprockets; vibration
damper; oil pump; water pump and housing; intake
and exhaust manifolds; flywheel with starter ring
gear; core plugs; valve covers; oil pan; turbocharger
housing and internal parts; turbocharger
wastegate actuator; supercharger; serpentine belt
tensioner; seals and gaskets for listed components
only.
Transmission: transmission case and all internal
parts; torque converter; drive/flex plate; transmission
range switch; transmission control module; bell
housing; oil pan; seals and gaskets for listed
components only.
NOTE: MANUAL TRANSMISSION CLUTCH PARTS
ARE NOT COVERED AT ANY TIME.
The main service contract we sell is the Maximum Care plan. As long as your car is under 48,000 miles and within 48 months from the in-service date, it is eligible for this coverage. It extends the 3/36 bumper to bumper to a 7 yr/70,000 miles.
This includes: All Electrical Systems, All Engine Computers, Shocks, Torsion Bars, Engine Mounts, All Seat, Hood, Deck Lid, Convertible Tops, Window Mechanisms, Engine, Transmission, Driveline, Steering, Air Conditioning, Engine Cooling and Fuel Systems, Front and Rear Suspension, Anti-Lock Brakes.
Other Exclusions
Your warranties don’t cover the costs of repairing
damage or conditions caused by any of the following:
• fire or accident;
• abuse or negligence;
• misuse — for example, driving over curbs or
overloading;
• tampering with the emission systems, or with a part
that could affect the emission systems;
• use of used parts, even if they were originally
supplied by DaimlerChrysler (however, authorized
DaimlerChrysler or MOPAR remanufactured parts
are covered);
• any changes made to your vehicle that don’t
comply with DaimlerChrysler Corporation specifications;
Huudoo, thanks. That is the coverage I have, and have had since before my car crossed the
36000 mile mark. With one exception. You cite 7 year/ 70,000 miles. However, my Maximum Care
plan covers 7 years / 100,000 miles. At just near 4 years and 2 months of ownership, I have 65+K
miles on the clock. I'm glad I got the 100,000 mile coverage.
Coyote
