Old Dec 3, 2008 | 07:18 PM
a12rag's Avatar
a12rag
Default Re: Heated seat failure
Spensly . . . I would reconsider using the spade connectors . . . trouble is how bulky they are. . .you will have to carve out an area in the cushion in order to have them located correctly and not showing any wrinkles etc. Also, there is the issue of possibility of the connector coming loose . . . I went as per the repair instructions and soldered everything and used the heat shrink tubing . . .
