Old Dec 5, 2008 | 08:00 AM
tighed1's Avatar
tighed1
Default Re: No Throttle Response...at 70 mph...
Originally Posted by paulius
Thanks for the ideas. I will have them checked out. Regarding the Johnson pump: would it cause my problem if the supercharger is not engaged? The throttle just stops working - no power at the peal- until the car is restarted. Even at 10 mph!
Paulius
Bad pump will cause over temp where the supercharger will be dis-engaged by the computer. You will still have throttle control but with a LOT less power.
Sounds like you have...
NO throttle response could be the accelerator pedal sensor, throttle control motor, throttle position sensor or the power control module.
