Huh? I could find nothing about this being used as a fuel.... Quite a bit of info concerning cancer treatment is available. Here is what is in Wikipedia:
Deuterium
From Wikipedia, the free encyclopedia.
Deuterium (symbol 2H) is a stable isotope of hydrogen with a natural abundance of one part in 7000 of hydrogen. The nucleus of deuterium (called a deuteron) has one proton and one neutron, whereas a normal hydrogen nucleus just has one proton. Deuterium is also called heavy hydrogen. While it is not an element in its own right, it is often given the symbol D. It occurs naturally as deuterium gas, D2 or 2H2.
Deuterium was first detected in 1931 by Harold Clayton Urey, a chemist at Columbia University. Urey earned the 1934 Nobel Prize in Chemistry for this work.
Deuterium is useful in nuclear fusion reactions, as is tritium, because of the larger rate of reaction (or cross section) and high energy yield of the D-T reaction.
Deuterium can replace the normal hydrogen in water molecules to form heavy water (D2O), which was a source of some concern during World War II, as Germany was known to be conducting experiments using heavy water as a nuclear reactor moderator, which might allow them to produce plutonium for an atomic bomb. This led to an important Allied special forces operation to destroy a deuterium production facility in Norway, known as the Norwegian heavy water sabotage.
Deuterium is frequently used in chemistry and biochemistry as a tracer molecule to study reaction pathways because chemically it behaves identically to ordinary hydrogen, but it can be distinguished from ordinary hydrogen by its mass. Also, because of its greater mass, chemical reactions involving deuterium tend to occur at a slower rate than the corresponding reactions involving ordinary hydrogen.
It has been suggested that deuterium water (heavy water) should be considered toxic because if consumed in isolation it would displace light water and disturb the rate of biochemical reactions in the body. See heavy water for a discussion of this.
The existence of deuterium in stars is one of the arguments in favour of the big bang theory over the steady state theory. Stellar fusion destroys deuterium and there are no known natural processes, other than the big bang itself, which produce deuterium.
Canada is the world's leading producer of deuterium as it is needed for the operation of the CANDU reactor.
Data
density: 0.180 kg.m-3 at STP.
atomic weight: 2.01363.
Data at approximately 18K for D2 (triple point):
density:
ice: 195 kg.m-3
gas: 0.452 kg.m-3
viscosity: 1.3x10-6 kg.m-1.s-1
Cp:
ice: 2950 J.kg-1.K-1
gas: 5200 J.kg-1.K-1
Retrieved from "http://en.wikipedia.org/wiki/Deuterium"
Categories: Chemical isotope | Nuclear physics
