Old Dec 9, 2008 | 09:32 AM
tighed1's Avatar
tighed1
Default Re: 60,000 Service...
Originally Posted by spheil
I have about 57,000 miles as well. And I've got some bearing noise coming from one of the pulleys. A friend that works on MB said that is common for these cars at or around 75,000 but said it should be in hours not miles.So if you sit in traffic much you might want to check these as well. Also the book said to change the fuel filter and the air filter at 60,000
Suggest that you get that bearing changed as soon as possible. Some of the members here have had damage done due to bearing failures. Most are from SRTs but you don't want the damage if you can avoid it.
