Old Dec 9, 2008 | 01:12 PM
maxcichon's Avatar
maxcichon
Default Re: 60,000 Service...
FSS Reset
1. turn the key to the on/run position.
2. within 1 second press the **** to the left of the display twice.
3. present status for days remaining or distance traveled is displayed. within 10 seconds turn key to off.
4. press and hold **** on left side of display while turning key to on/run again. present status is displayed once more. continue to hold button. after approx. 10 seconds a tone sounds and the display shows 6,000 miles for approx. 10 seconds.
5. release the ****
You should be able to do this. It takes a few attempts to get it right. One pointer ...the 10 seconds in step 3 refers to 10 seconds after the key is turned to the ON position. You have to turn it off before that expires.
Throttle Reset
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
ESS/BSP Reset
1. Turn on the engine
2. Rotate your steering wheel all the way to the left and then all the way to the right.
3. Drive normally. The light should go off.
Lamps
2005 CHRYSLER Crossfire
Low beam headlamp
H7
H7SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
H7ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H7XV XtraVision Halogen - The Brighter Light
H7CB Cool Blue Halogen - The Whiter Light
H7LL Long Life Halogen: Lasts two and a half times longer
High beam headlamp
H7
Parking light
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
7507A
7507AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Rear turn signal
7507A
Tail light
7528
7528LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
7528
Fog/Driving light
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
Back up light
7506
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
2825
Rear sidemarker
2825
Glove box
6418
6418LL Long Life Upgrade: Up to twice the life of the standard lamp
Trunk/Cargo area
6418
Filters
K&N
2005 CHRYSLER Crossfire 3.2L V6 F/I - All (2 required)AutomotiveAir Filter33-2290
2005 CHRYSLER Crossfire 3.2L V6 F/I - AllAutomotiveOil FilterHP-7004
2005 CHRYSLER Crossfire SRT-6 3.2L V6 F/I - All (2 required)AutomotiveAir Filter33-2256
2005 CHRYSLER Crossfire SRT-6 3.2L V6 F/I - AllAutomotiveOil FilterHP-7004
Paper Filter (Oil) MB #000 180 22 09
http://cgi.ebay.com/ebaymotors/C-CLK-E-ML-320-32-AMG-Mercedes-Benz-Oil-Filter-Set-of-4_W0QQcmdZViewItemQQcategoryZ33661QQihZ022QQitemZ3 50002784280QQtcZphoto
Fleece Filter (Oil) MB # 000 180 26 09
http://cgi.ebay.com/ebaymotors/Mercedes-Benz-C-CLK-E-ML-SLK-320-32-FLEECE-oil-filter-4_W0QQcmdZViewItemQQcategoryZ33661QQihZ022QQitemZ3 50002786204QQtcZphoto
Filter Tool (Oil)
http://cgi.ebay.com/ebaymotors/BMW-Mercedes-Benz-Porsche-VW-oil-filter-tool-Wrench_W0QQcmdZViewItemQQcategoryZ43994QQihZ022QQi temZ350003123001QQtcZphoto
Links with pictures and pricing on QTY of 4 - Cheaper the MB Dealer, Chrysler Dealer, oempartsdirect.com and your local Auto Parts Store (unless you want a cheap filter protecting your engine for 7K miles).
I change filter elements every 3,500 miles and Oil/Filter every 7,000 miles.
OEM Wheels and Tires
http://www.rims-n-tires.com/rt_specs.jsp
http://www.chrysler.com/en/owners/
http://wyckoffchryslerparts.com/
http://www.mercedesshop.com/Wikka/Trans7226Fluid
http://slk32.com/pages/diffoilchange/diffoilchange.html
http://www.tradebit.com/filedetail.php/2158990-2005-chrysler-crossfire-factory-repair-service-manual
http://homepage.mac.com/gregmeach/XFire/
http://www.chryslerpartsdirect.com/
http://www.ctd-germany.com/shops/crossfire/shop_e/index.php
