Old Dec 10, 2008 | 03:04 PM
07bluezx14's Avatar
07bluezx14
Default re: HID Install Lows and Fogs with Pictures
I have used 4 kits off of ebay, and they work great. and are very easy to install, once you can get to the passenger side. I would suggest you do that side first, as it is the more diffucult to get to. Try using something like robo grips, to lift the overflow resevoir from underneath, I tried to just pull it out, but 1 hour later, and the robo grips lifted it right out of the grommet. good luck, chris
And save your self a trip to the parts store, and pick up the m6 nuts. your going to need 4 most likely.
