Old Dec 11, 2008 | 01:38 PM
downwardspiral's Avatar
downwardspiral
Default Re: pre and post feb 04 flywheels
Originally Posted by import_trung
hey all,
ive got a pre feb 04 manual xfire 3.2 coupe (112 engine), and the engine has let go.
now i've purchased a used replacement engine out of an auto 06 model.
but the problem ive got is that the flywheel bolts dont all line up.
at first i thought it was because there was a difference between the auto and manual engines.
ive called chrysler UK and they've said that there are 2 flywheels available, pre and post feb 04.
each one is £600 a pop and there is a no returns policy. so buying them both to compare is outta the question.
so can any one help verify that there is a bolt pattern change?? pictures of the crank or flywheel would be greatly appreciated.
pre 04 has equidistanced spaced bolts, whereas the post 04 has offset bolt pattern. but is it an auto to manual difference or a year difference.
It is very plausible that they did change it, but if I'm not mistaken a manual uses a flywheel and an auto uses a flexplate. At least with older cars...
