Old Dec 11, 2008 | 05:19 PM
James1549
Default re: DIY Transmission leak fix with photos... TA DAAaa
So is the leak actually the O-rings or the connector itself?
In step 6, you mention trans fluid leaking out. Should that be or is that where the problem is.
I work with similar connectors on Allison and Voith transmissions. Just unplugging the wire harness plug, you shouldn't get any fluid spill.
James
