nothing is impossible :wink:
6.1-liters displacement from eight cylinders, 426 hp maximum power output, a peak torque of 458 lb-ft, 0 - 60 mph in 4.6 seconds and a top speed of 186 mph
The STARTECH suspension concept for the STARTECH Coupe V8 6.1 also comprises custom- tailored tire/wheel combinations with 19- and 20-inch staggered tires. Steering commands are transmitted to Pirelli tires in size 235/35 ZR 19, mounted on one-piece STARTECH Monostar IV 8.5Jx19 five-spoke wheels. 255/30 ZR 20 high-performance tires on 9Jx20 wheels guarantee maximum traction on the rear axle.
The STARTECH high-performance brake system features six-piston aluminum fixed calipers and 355-mm vented and cross-drilled discs on the front axle in combination with 300-mm discs and four-piston aluminum fixed calipers in back. This system offers maximum stopping power and maximum endurance at all times.
The high speeds attained by the STARTECH Coupe V8 6.1 necessitate optimum aerodynamic efficiency. To reduce lift on the front axle and to give the coupe even more passing prestige STARTECH designers and aerodynamics engineers developed a front spoiler attached to the stock bumper.
Lift on the rear axle is minimized by the STARTECH diffuser inserts for the stock rear bumper, a STARTECH roof spoiler and the three-piece STARTECH rear spoiler, whose center piece is extended together with the stock rear spoiler.
