Old Dec 12, 2008 | 10:58 AM
waldig's Avatar
waldig
Talking re: DIY Transmission leak fix with photos... TA DAAaa
Here is something that may be of use, Oil is great for terminals, that do not move. It cools the connections and insulates them from moisture, see the power transformer on your lawn or power pole.
High tension switches are immersed in oil to quench the arc during switching.
The socket and pins are wet (ATF) on the transmission side and not affected by oil. When I put connectors together for the car, I spray them before assembly with white lithum grease ( Thanks Ford for the idea). For spark plug boots I always add silicone grease so they will release later. Back in the day when I admitted to doing TV repair, there was a spray contact cleaner and lube for pots and switches - especially the rotary tuner contacts........
Sorta like the advice I give to young couples with children - to use vasoline brand grease during sex activities. It really works well and makes everything go much better. Not a lot is actually needed in reality. You dont need to use much, just a thin even coat to completely cover the door **** .
This helps keep the kids out...........Priceless
Enjoy Woody
