Old Dec 13, 2008 | 08:33 AM
  #38 (permalink)
ronfisher1's Avatar
ronfisher1
Default Re: How to program your own key. SAVE $$$
Originally Posted by ImportLabSRT
No.... when you order a key from Chrysler (which is cut at MB lock and key in Fort Worth) they program the EIS code for your vin into the key. The above mentioned programing is just to sync the key for the keyless entry. Once a key is programmed, thats it, it cannot be programmed to another car. Hope that clears it up a bit. I work wholesale parts at a local MB dealership and just had a hell of a time getting a 2nd key from Chrysler.... long story short, it was cut wrong and I had to send my only key to F.W. Texas for it to be cut right.
I recently bought a keyfob from ebay with a blank key, Iwas able to get a local locksmith to cut the key. The key worked great but the fob could not be reprogramed to work with my Xfire ,I was then told I would need to order a new FOB from the factory at 143.00 dollars. So yes the above is true. You need a new FOB which will come with a new key Cut.
